For information about displaying port speed, duplex, auto-negotiation, and flow control settings, see Displaying Port Information.
Stacking ports always use the same type of connector and copper PHY, which are built in to the ExtremeSwitching switches. You cannot configure stacking port parameters such as port speed, duplex, and link fault signal. You also cannot configure data port features such as VLANs and link aggregation.Auto-negotiation determines the port speed and duplex setting for each port (except 10 and 40 Gbps ports). You can manually configure the duplex setting and the speed of 10/100/1000 Mbps ports.
The 10/100/1000 Mbps ports can connect to either 10BASE-T, 100BASE-T, or 1000BASE-T networks. By default, the ports autonegotiate port speed. You can also configure each port for a particular speed (either 10 Mbps or 100 Mbps).
With auto-negotiation turned off, you cannot set the speed to 1000 Mbps.In general, SFP gigabit Ethernet ports are statically set to 1 Gbps, and their speed cannot be modified.
However, there are two SFPs supported by Extreme that can have a configured speed:
The 10 Gbps ports always run at full duplex and 10 Gbps. The 40 Gbps ports always run at full duplex and 40 Gbps.
ExtremeXOS allows you to specify the medium as copper or fiber when configuring ExtremeSwitching switches with combination ports. If the medium is not specified for combination ports then the configuration is applied to the current primary medium. The current primary medium is displayed in the Media Primary column of the show ports configuration command output.
For switches that do not support half-duplex, the copper switch ports must have auto-negotiation disabled and full duplex enabled when connecting 10/100/1000 Mbps devices that do not autonegotiate. If the switch attempts and fails to auto negotiate with its partner, it will fail to link up. A non-negotiating connected device must also be manually configured for full duplex or packet loss and port errors will occur each time it detects a collision.
Beginning in version 32.4, auto-negotation defaults to ON for SFP28, QSFP+, and QSFP28 ports (25G/40G/50G/100G).To configure port speed and duplex setting , use the following command:
configure ports port_list {medium [copper | fiber]} auto off speed speed duplex [half | full]
To configure the system to autonegotiate, use the following command:
configure ports port_list {medium [copper|fiber]} auto on {[{speed speed} {duplex [half | full]}] | [{duplex [half | full]} {speed speed}]}
The keyword medium is used to select the configuration medium for combination ports. If port_list contains any non-combination ports, the command is rejected.ExtremeXOS does not support turning off auto-negotiation on the management port.
The following table lists the support for auto-negotiation, speed, and duplex setting for the various types of ports.
| Port | Auto-negotiation | Speed | Duplex |
| 100 Gbps |
On (default) Off |
100,000 Mbps | Full duplex |
| 10 Gbps | Off | 10,000 Mbps | Full duplex |
| 40 Gbps |
On (default) Off |
40,000 Mbps | Full duplex |
| 1 Gbps fiber SFP |
On (default) Off |
1,000 Mbps | Full duplex |
| 100 FX SFP |
On (default) Off |
100 Mbps | Full duplex |
| 10/100/1,000 Mbps |
On (default) Off |
10 and 100 Mbps 1,000 Mbps |
Full/half duplex Full/half duplex |
| 10/100 Mbps |
On (default) Off |
10 Mbps 100 Mbps |
| 100/1000/2.5 Gbps |
On (default) Off |
100 and 1,000 Mbps 2,500 Mbps |
| 100/1,000/2.5/5 Gbps |
On (default) Off |
100, 1000, and 2,500 Mbps 5,000 Mbps |
Full duplex Full duplex |
25 Gpbs |
On (default) Off |
25,000 Mbps | Full duplex |
| 10 Gbps SFP+ | Off | 10,000 Mbps | Full duplex |
50 Gbps |
On (default) Off |
50,000 Mbps | Full duplex |
For Universal Hardware switches, auto-negotiation is disabled by default when a 1G SFP optic is inserted in a 10 Gbps SFP+ port.
Half-duplex is not supported on the multi-rate ports of ExtremeSwitching 5520-12MW-36W. Half-duplex is supported on the copper ports of 48T/W and 24T/W at 10/100Mbps, but not at 1000Mbps.Flow control on Gigabit Ethernet ports is enabled or disabled as part of auto-negotiation (see IEEE 802.3x). If auto-negotiation is set to Off on the ports, flow control is disabled. When auto-negotiation is On, flow control is enabled.
With Extreme Networks devices, the 1 Gbps ports and the 10 Gbps ports implement flow control as follows:
When 1G SFP optics are inserted into 10 GBps ports, you must configure auto-negotiation "on" with 1G speed.ExtremeXOS allows you to enable IEEE Forward Error Correction (FEC) Clause 91 or Clause 74 (exclusively) on a per-port basis regardless of speed/type.
FEC gives the receiver the ability to correct errors without requiring a reverse channel to request retransmission of data, but at the cost of a fixed, higher forward channel bandwidth. Some devices require this to interoperate.
FEC is only available on 4120 SFP28 and QSFP28 ports, 4220 SFP+ ports,ExtremeSwitching 5420-4XE ports, 5420-4YE ports, 5520-VIM-4YE ports, 5720 QSFP ports, 5720-VIM-6YE/2CE ports, and Extreme 7520-48XT.
To enable/disable FEC, use the following commands:
configure ports port_list forward-error-correction [off | on [cl74 | cl91]]
To show FEC status, use the following commands:
show port port_list forward-error-correction {refresh | no-refresh } port-number
show port {mgmt |port_list | tag tag} information {detail}
